BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
9 members (Gib70, bucktruck, 1942-G506, greenie-reddy, Lightholder's Dad, 2-Ton, Otto Skorzeny, JW51, Peggy M),
588
robot. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,258 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Aug 2012 Posts: 44 Wrench Fetcher | Wrench Fetcher Joined: Aug 2012 Posts: 44 | I am pulling the 216 engine & 4 speed trans from my 48 chevy P/U this weekend. I will be swapping it with a 1954 235 that also has the factory 4 speed trans. The 1948 chevy truck manual references a K-353 gearshift remover for this task. Can this tool be rented or does someone have a suggestion on what can be used instead to disengage the lugs on the retainer? Down the road when I can afford to I would like to put a T-5 trans but will have to putt around for the time being. Thanks
Keith
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Push straight down on the lever and twist/rotate left 90 degrees. It will pop out, like magic. If that does not work, clamp a vise-grip or slip-joint where the tool is placed in the illustration , rotate as described in the manual. | | | | Joined: Mar 2007 Posts: 4,185 Moderator | Moderator Joined: Mar 2007 Posts: 4,185 | Just pretend you're taking a tail light bulb out of the socket, same principle, just a bit tougher. I have done it bare handed many times. | | | | Joined: Mar 2002 Posts: 9,112 'Bolter | 'Bolter Joined: Mar 2002 Posts: 9,112 | I use a pipe wrench with the open part placed like the tool and using downward pressure. I found the rotation needed is about 20 degrees. | | | | Joined: Aug 2012 Posts: 44 Wrench Fetcher | Wrench Fetcher Joined: Aug 2012 Posts: 44 | Wow, that simple huh? Thanks as I was really sweating this task. I am so thankful for the advice.
Keith
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Wow, that simple huh? Thanks as I was really sweating this task. I am so thankful for the advice. I was also worried about this, until I just tried it. | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | Shop Shark Joined: Jan 2009 Posts: 1,644 | When I started on the "project" a 53 3/4 ton GMC I had a heck of a time getting the shifter out of the trans.What I had to do was spray the retainer with some WD40 and tap it down with a plastic hammer,it was packed with sand that had gotten hard from setting for ten years.Once it popped up and down on the spring I just pushed it down and gave it a twist and it came right out.
Pete | | | | Joined: Aug 2012 Posts: 566 Shop Shark | Shop Shark Joined: Aug 2012 Posts: 566 | Yes I too went to auto zone and napa to see about purchasing the tool but I did mine by accident. It was done with a large channel lock pliers. I just strattled the gear shift lever with the grip handles of the channel lock pliers and i was joking with a friend I pushed down and then i turned it and it poped up.
good luck
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
