6 members (55shaker, 54farmtruck, Hotrod Lincoln, Bill Hanlon, MNSmith, 1 invisible), 118 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
Hey guys, I toying with the idea of converting my 1953 3800 to 12 volt. My question is if I decide to change the guages ans use a Programmable Speedometer will the sending unit work on my stock 4 speed tranny?
If it's broke hit it harder!
I'm not sure what you mean by "programmable speedometer". Do you mean an electric one? If so, as long as your tranmission uses a cable currently, the sending unit should work fine. That's assuming the thread is the same too. Hopefully someone else can chime in.
My 46 GMC on Photobucket
Yes, I do mean an electric speedometer. And the thread matching up is the issue I was worried about. Does anyone know off hand what the thread size is on a stock 4 speed?
Don't know the answer, but I have read on this site that speedometer repair shops have various adapters for making things match up. Might be worth a few calls!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
