0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
Junior Member
Junior Member
I'm rewiring my 1938 Chevy 1/2 ton, and I have all of the wires replaced except the wire running through the steering column. I can see where the wire exits the column at the bottom, and when I pull the steering wheel I can see the contact ring down inside the column, but I can't figure out how that contact ring comes out to attach a new wire. Any hints ?
Alex Meade
Lexington, KY
Beneath the horn button assembly, there is a mast bearing that needs to be removed. With the proper puller, it can be removed intact. Since few of us have the puller, you can remove the bearing and replace it with a new one. Here's a tech tip on it. Horn tech tip
Fred
52 3600
69 C-10
