| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | My running boards have some sort of undercoating on the underside of them. How can I strip it to prep for painting? Looks like it was brushed on. It's holding well and not rusted underneath. Probably should have left it, but I've started stripping it so I guess I gotta finish it. Does anything work faster/better than what I am using ... Klean-Strip 10-min "Strip-X" to melt it. Then scrub with a brass or steel brush. Wash and scrub more with gasoline. I found that a little kerosene in the gas will slow evaporation. Using a lot of paper towels. I will probably lightly sand blast it after the coating is off. Can't seem to remove all of it at the joins where the supports are attached. Looks like both sides of the boards were painted with red primer before painting and/or undercoating. Here are some work-in-progress pics: > Underside stripped vs orig> Underside close partially stripped vs orig> Underside coating close up> Top partially stripped vs origThanks for your help,
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | One of my old projects was coated in and out with looked like roofing tar. I used a propane torch, putty knife, and kerosene to clean it off, and it turned out great.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | some heat and a putty knife or a wood chisel will get the bulk, sand blasting works pretty good most of the time | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I'm learning that there is no fast and easy way to remove this stuff!
Just about finished with the underside of one running board. The undercoating was probably applied when the truck was restored about 20 yrs ago. It's still a little soft. I used a heat gun and a putty knife for a while today. I got the best results without the heat gun using a putty knife, a screw driver, a wood chisel, and anything else that I could find to scrape/cut off the coating. Applied some more stripper to the stuff that remained. Then scrubbed with gasoline, a rough ScotchBrite, and a toothbrush. Rinse and repeat.
My li'l HF siphon sand blaster with play sand cuts the steel more than the coating. I'll use it for the final prep for painting.
I'm impressed that the original e-coat is still on the running boards and in good shape. However, the ScotchBrite is removing it. Sandblasting will finish removing it.
I'll post my saga and results when I finish the job. Thanks for your help and suggestions.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've had good results scrapping it off with a putty knife. I do use some carb cleaner spray and it does loosen it some in tough areas. I have found heat makes it smear more and get harder to get off. | | |
