1 members (GMCJammer51),
117
Mod | | | Forums66 Topics128,186 Posts1,057,324 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Drove my 50 to work today for the first time since June. (17 miles from home)
Had less than 1/4 tank of gas this morning so I added 3 gals of fresh gas on the way in to work. Added sty-bil to tank
Temp when I left work about 102.
On the way home made a stop after about 8 miles . Noticed a dribble of gas running from the fill neck. Thought it was strange because I had less than 1/2 a tank so I knew it was not over full and expanding. Pulled cap and heard a pressure release. wiped the area clean
Continued on my way home, got on the freeway and truck started bucking a few times. I pulled over and as I was coasting I could tell the truck shut down, still coasting to the side the engine fired back up. Slowly got her back up to speed 45-50 mph.
Made it back home OK , pulled into the garage and noticed more dribble of gas from the filler neck.
Is this a symptom of the gas cap not venting? any other ideas? If the cap is not venting will it cause the truck to buck?
thank you | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Wow, not sure about the dribble, but if the cap can't vent, you get vacuum in the tank, and the fuel pump may not be able to pull the gas out. That will certainly cause fuel starvation. Gas expands alot, but even when it's hotter than......Reno, you won't get a full tank!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | get a new vented cap, problems solved
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks
Ill give a new cap a try
I suspected this issue might be the cap, just wanted to make sure the Bucking and dribbling filler neck were both symptoms of a bad cap. Didnt have the issue in the cooler morning drive (80 degrees 4am)
Ill try my local FLAPS for a cap. | | |
