5 members (Youngin' Tut 59, klhansen, DadsFirstPickup, BarryP, 1 invisible), 73 guests, and 2 robots.
Topics128,139
Posts1,056,758
Members48,454
Truck is a 56 half ton. There are eight bolts holding the seat to the floor, two at each corner. The holes in the brackets match up with the holes in the floor up front. But at the back of the seat, the holes are off by quite a bit. It looks like if I could rack the seat mounts some, I could get them to match up. Are they adjustible?
1956 Chevy 3200
Those brackets with the eight holes are riveted to the tracks and are not adjustable but the tracks are bolted (with clutch head screws)to the underside of the seat. If you loosen them you should be able to adjust the tracks enough to line up with the holes in the floor. Also, if the seat has been out of the truck for a while and has been getting knocked around those brackets that sit on the floor could be a little out of whack (bent), just bend it back.
OK, thanks a lot. I saw that the brackets were attached with clutch head screws. I'm going to have to take the seat out and adjust them.
1956 Chevy 3200
Moderated by  ndkid275, Phak1
