| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87948 04/18/2002 2:53 AM | Joined: Jan 2002 Posts: 14 Member | | Member Joined: Jan 2002 Posts: 14 | I'm rewiring 53 chevy 1/2 ton.It is converted to 12 volts already. Found a componet about 3/4 diameter by 2" long. one end is connected to amp gauge the other was not connected at all.Does it go to gas gauge? Gas gauge was not working before it started to rewire. There is a number on it. 7257919, .5MFD, 200V.D.C. What ever it is do i need it? And how do i test it? | | |
#87949 04/18/2002 3:21 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Odd, that appears to be a .5 microfarad, 200v capacitor. Not sure why you'd have one of those connected to the ammeter. (Capacitors block DC voltage.)
If you're using the stock, 6 volt gauges, you will need resistors to reduce the voltage to 6 volts for the gas gauge. Randy Rundle, who is the Garage Foreman here, sells a Runtz voltage reducer which will do the trick. Don't recall the price off hand, but you can find a link to him on our Links page. You can also just go to Radio Shack and buy a proper resistor (but I don't know what values you'd need.) | | |
#87950 04/18/2002 4:27 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I have heard of people using capacitors as noise filters for radios and stereos. Maybe the capacitor was used for something like that? | | |
#87951 04/18/2002 4:54 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like someone's attempt at a filter capacitor to eliminate static in the radio. Used to be able to buy one from JC Whitney that was about 6" long, worked best if mounted near or on the generator. I put one on a Mack that I drove, it did help with the CB.
Fred 52 3600 69 C-10
#87952 04/18/2002 5:31 PM | Joined: Jan 2002 Posts: 14 Member | | Member Joined: Jan 2002 Posts: 14 | Thanks everyone for the help. Can you advise how to check the gas gauge in case it did burn out? | | |
#87953 04/18/2002 7:27 PM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Here's how the gas gauge system works: - You have 6 volts going to the positive terminal of the gauge.
- The negative terminal is wired to the float in the gas tank
- The arm of the float has a needle that rubs across some windings (called a potentiometer)
- When the float is high, there is some resistance to ground
- When the float is low, there is very little (if any) resistance to ground
So, you can put 6 volts on the + side of the gauge and then ground the negative side. Then remove the ground. In one position, the gauge should read full, in the other it should read empty. | | |
#87954 04/19/2002 2:58 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | | | |
