| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87902 03/17/2005 5:01 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | So, I'm at one of the most congested intersections (1st Ave S/ Marginal Way at the First South Bridge for you Seattleites) at rush hour (5:20 pm) when it starts to rain for the first time in a month. I'm the first vehicle at a red light. Behind me is a Kenworh with two trailers. Everytime the light goes green, about 5 cars get through. Nerves are frazzled. I turn on the wipers and the truck goes dead. Stone cold. Guages all go off. The light is about to go green when I get out and start pushing. I'm in the left lane so I push into the traffic coming off the bridge hoping that they will just back off. I push in front of the two right lanes of traffic and up into a driveway at Seattle Fish. I have just enough energy to get the tail end out of the roadway when the light changes. My heart was pounding like a steam hammer and my legs were shaking. I got out the cell phone and dialled a "9" and a "1". I hovered my thumb over the keypad waiting to hit that last "1" in case it's THE BIG ONE! Things settled down, I guess all that walking and bicycling paid off. I called AAA instead of 911, and got towed home by a big Chevy Duramax.
Where do I start my troubleshooting?
"Happiness equals reality minus expectations" - Tom Magliozzi
#87903 03/17/2005 5:20 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | with the vehicle you were driving!!  if it was the ol bolt, sounds like electrical to me - like the battery or connections - maybe poor ground - sudden current draw finished off a weak connection - maybe even wiper motor shorted out - good luck!! Bill | | |
#87904 03/17/2005 5:33 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Jim Bow: "In Seattle, chili has beans." Get the beans out of your chili and then maybe I can help... Oh, and I got a call today from a buddy looking for a sys admin to work on Bainbridge. Interested in an opportunity to get out of that Seattle traffic? Three possibilities that I think of immediately: 1) Coincidence unrelated to wipers... 2) Electrical fault in the wiper circuit that killed the electrical system. 3) The wiper mechanism shorted the ignition circuit. Is this your '59? Is the wiring stock? No smoke, sparks or melted plastic?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#87905 03/17/2005 6:25 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Now that it's had a chance to dry off, does it start and run OK?
Gord 1954 1/2 ton 235 4 speed
#87906 03/17/2005 12:08 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | I think it might have somthing to do with the battery or it is not charging. Charge the battery and see if it will start. | | |
#87907 03/17/2005 2:11 PM | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | I'm guessin either voltage regulator or alternator--prolly the later. When you turned on the wipers overwelmed the system and down she went. Insufficient voltage.
Buzz'n Half Dozen
#87908 03/17/2005 4:27 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | were you in an automatic transmission? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87909 03/17/2005 10:42 PM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Thanks for all the tips. Stock wiring as far as I can tell. There's a couple of pieces of zip cord in there that I'm not too sure of. It's not the stock ignition switch either. The wipers moved about ten degrees and then the whole thing stopped.
#87910 03/18/2005 10:20 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well the first rule of trouble-shooting is to divide the entire system into pieces and check the sub systems until you find the one where the failure is occuring.
The truck and wipers both died at the same time. Are the wipers electric? If so its probably an electrical problem. If the wipers are vacuum I would not assume an electrical problem.
Is the battery charged? If the battery is okay, turn on the ignition and check for power to the coil. If you have power to the coil check out the ignition system because most likely the running problem isn't related to the wipers, but rather to ignition.
If no power at the coil, check the ignition post on the ignition switch. If you have power there the problem is between the switch and the coil. If you don't have power at the switch its the switch itself (check to see if you have power on the batt post on the switch) or between the switch and the battery.
Given the apparent connection between switching on the wipers and everything dying I'd look particularly for wiper control arm and wiring that are touching. If you reported smoke or sparks I'd guess the wiper control arms cut into one of the wires to the amp meter.
But since you didn't say smoke it may be something else...
Divide and conquer! Keep checking until the problem is localized to one part of the circuit, and then replace or repair that part.
#87911 03/22/2005 3:16 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | OldSub and everyone else. I crawled in upside down beneath the dash with a MagLite in my teeth and found a cut brown wire dangling from the vacinity of the wipermotor. Unknown if it's a stock brown wire or a replacement brown wire, I'll get to it next weekend. I guess I'll have to remove the seat in order to work under there for any length of time. Hope it's sunny and warm.
#87912 03/22/2005 3:19 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | OldSub and everyone else. I crawled in upside down beneath the dash with a MagLite in my teeth and found a cut brown wire dangling from the vacinity of the wipermotor. Unknown if it's a stock brown wire or a replacement brown wire, I'll get to it next weekend. I guess I'll have to remove the seat in order to work under there for any length of time. Hope it's sunny and warm.
#87913 03/22/2005 3:20 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Hmmm how'd I do that? Hmmm how'd I do that?
#87914 03/22/2005 5:28 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I hate hanging wires.
I take a drastic approach to loose wires. I hack them all out.
A couple weeks ago I went wild and removed every wire I could find from a buddy's truck. Another few weeks and we'll put all new wire in it. It should be a lot happier then!
#87915 03/22/2005 4:41 PM | Joined: Mar 2003 Posts: 46 Member | | Member Joined: Mar 2003 Posts: 46 | i HAD THE SAME PROBLEM WITH MY 53 CHEVY , IT TURNED OUTY THE POINTS WERE DIRTY. TRY THAT ROOT. | | |
#87916 03/27/2005 8:34 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If your ignition is fuzed and the wipers are wired through the ignition switch, the fuze could have blown. The starter would still turn over if this is the case unless you have a starter relay running through the same fuze. A brown wire is normally hot all the time and it may have burned rather that been cut. Perhaps it supplies the power to the ignition switch? The first thing to check would be the connections on the battery.
Baldy | | |
