| | | Forums66 Topics128,192 Posts1,057,351 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 6 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 6 | running a 50 chevy pickup with a camaro subframe, SBC with short water pump set up. I was using a Chevy Duty desert cooler radiator. Worked fine but would run hot and burp if in crawling traffic. On second tear down and was given a Walker cobra radiator. Not fitting real well with the engine, not enough room to run a mechanical fan and or an electric fan. Really dont want to run a pusher. Debating going back to a desert cooler and mechnical fan. Any one have any idea's or used a walker before? Was also considering the aluminum rad from Chevy duty but wasnt sure if it was better or worse on fit and running hot? I would be Interested in some feedback | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Do you have a fan shroud? It will really make a difference. I'm running a 350 in my AD and it lowered the temp by 10 degrees. | | | | | Joined: Apr 2008 Posts: 17 New Guy | | New Guy Joined: Apr 2008 Posts: 17 | I ran an original 6 cyl. radiator for years. Took a trip from Atl to Maine with out heating probs. Even in NYC. Had external trans and AC coolers. My setup is a SBC in a '70 Monte Carlo front clip. I am rebuilding truck and had local radiator guru install new core. LOL.. old cap was 7psi, and it worked for nearly 30 yrs. No shroud, no electric fan.I may try a shroud this go round to see if temp drops any. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I love my American Eagle aluminum radiator in my '50. It is rated to 400 HP if I remember correctly, and runs at 180 degrees all day in the Idaho heat with an electric pusher fan. It fits in the original location too.
Best of all, ~$180.00 shipped to the door!
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | You did not mention what water pump you run. I use an Edelbrock high flow short pump. I have run Stewart pumps as well with great success. The high flow impeller design does make difference.
I have an aluminum radiator from US Radiator with a spal 16 inch puller fan. The fan has the curved blades and is the highest cfm 16 in they make. I have the largest AC condenser I could fit and a B&M alumium external trans cooler mounted in front. So the airflow has to go through those first. The radiator has a trans cooler that is plumbed in as well. The fan sits as high as I could mount it to the top of the radiator since it is a down flow. I could not fit a shroud but would have if I could. The trans cooler sits low as possible in front. Mostly for fitmentg and appearance.
The engine is a ZZ383 rated at 425 hp. I run a 180 stant thermostat and have an overflow tank. Never runs hot even with our 90-100 degree weather. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I think 49panel has the best tip on running external coolers. 1951 GMC with 500 Cadillac, GOOD stock radiator, external cooler, a-c and home made shroud, has been going since 1976 with no heating problem in 105 Texas heat.
Evan
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'm running a Walker Cobra with air, 350, 330 horse, 700R4 tranny cooled by the radiator. I'm using a pull for the rad and a push for the condenser. In the Texas heat 90-105 she runs 190 at long idle with outside temp at 102. Hope this helps.
~Jim
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I adapted a stock truck radiator into my '52 3/4 ton. I fabricated my own sheetmetal fan shroud around it, and it never runs hot, not even sitting in traffic for extended periods of time. I was running a 350, but that wore out and now I have a 283 in it.
If you can get the aftermarket radiator that fits in the stock location, that would be best. But it is expensive, around $600 bucks I think. Maybe in your case, ADpartsman, an electric pusher fan on a switch inside the cab might help keep its cool when you're stuck in traffic.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Apr 2005 Posts: 6 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 6 | thanks for all the input! | | |
