3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#87884 05/24/2002 9:06 PM
I'm taking apart a 51 1/2 ton AD speedometer for refinishing and can't get the needle socket off the shaft.
As far as I can tell it's a friction fit and should just pull off. Probably it's a friction and corrosion fit by now. Does anybody know any tricks for pulling off the socket and needle hub without snapping the shaft?
I thought about adab of penetrating oil like PB Blaster, but they are pretty small pieces.
Never start vast projects with half vast ideas.
#87885 05/24/2002 10:14 PM
The trick is 'you take your chances'. Some insist that you have to twist off clockwise, I have wound up with many 'clock spring on a stick' so the trick is to remove the needle at the junk yard, and if it does not work, try another speedo.
57 3/4 ton rat
66 C-10 panel 350 200R4 3.07 axle
68 C-20 dump runner, 250 4spd, 4.11
82 Camaro, 305, THM-200-R4
84 Monte Carlo, 350, TH350
EVERETT, WA
#87886 05/24/2002 11:21 PM
What about very carefully applying a little heat to it? If you can get the outer piece to expand more than the shaft, it might come off. I'd hold a match over the round disk and let it heat from the bottom of the flame, no warranty implied or otherwise! Or touch it with a small soldering iron. It's not plastic, is it?
#87887 05/25/2002 6:34 AM
Every speedo needle that I have taken off I did so by CAREFULLY twisting in one direction while gently pulling. IT has worked every time [img]http://www.thevirtualgarage.com/bboard/ubb/biggrin.gif[/img]
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#87888 05/27/2002 7:00 PM
Okay. I tried redshiba's advice first. I twisted carefully against the stop (counterclockwise) and gave the needle cap a slow firm pull. It came off as advertized. Maybe it was just luck. Anyway it saved another trip to the junk yard that tpsierra recommended. I didn't get around to trying heat on the socket. Probably a soldering iron would have been ok. But this time twist and pull worked just fine.
Thanks a whole lot for all the good advice. Somebody oughta write a book. wink
