5 members (SmalltownTRKGuy, GradyB, 78buckshot, rfs56trk, 60steve), 203 guests, and 4 robots.
Topics128,204
Posts1,057,290
Members48,467
I am putting together a 65 chevy 230 6cyl drivetrain together and i am needing the mounts where the bell housing mounts to the cross member. I cant seem to find them online. are these available?
Well i guess they are not available. Is there any alternative i can use?
OLTrucks
Unregistered
OLTrucks
Unregistered
Your local FLAPS sould have these they are the same form 1954 - early 70s they are two piece one upper U shaped and the lower fits in the channel of the cross member.
Thanks. I'm assuming FLAPS stands for Full Line Auto Parts Store? LOL?
And two are required right?
Okay, I saw an image. So I will need two lower and two upper right? So on these trucks you have two motor mounts of course then just these 4 pieces for the transmission at the bell housing and that's it? No additional pad on the rear center like an GM auto trans. huh? Thanks.
I'm sorry one more question. What size/ thread pitch of bolts do I need for this?
