0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87785 03/25/2003 9:47 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | can a coil leak out it's electrical stuff like spark plug wires do? I know that you can see(sometimes) at night when a plug wire might do this, I am speaking of the coil on my 235 eng. Thanks, ,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87786 03/25/2003 10:26 PM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Sure. If the tower is cracked or the boot over the tower is cracked, it can leak. You can also get the same thing from carbon tracking or dirt deposits. Easiest way to tell if you have a problem is to hold a grounded, plastic handle screwdriver near the coil tower and see if any spark jumps to the screwdriver. Don't touch the tower, just get near to it. And make sure the ground is secure and your hand isn't touching the metal shaft of the screwdriver.  | | |
#87787 03/26/2003 1:11 AM | Joined: Oct 2001 Posts: 10 Member | | Member Joined: Oct 2001 Posts: 10 | Coils also do get tired over time. They are not big bucks, I replace mine fairly regularly. I encountered somewhere recently (perhaps here, but I think not) that 12 volt systems need a current limiting resister on the low voltage side of the coil, 6 V systems do not. A 6, converted to 12 won't have this resister in place. The coil can get pretty hot if the ignition is left on without the engine running. This will be hard on the coild over time (it could boil out the oil or what ever is inside them). Just a thought David | | |
#87788 03/28/2003 8:55 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Thanks guys, think that I found the problem that has been giving me fits for a long time, when I pulled the coil wire out of the coil, I found the top of the coil where the coil wire goes in very corroded, clean it out the best I could with sand paper and so for no more dieing, skiping of the motor,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#87789 03/28/2003 9:27 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Should be no more that 12 to 15 bucks at the autoparts store
