0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#87763 03/09/2004 4:18 AM
Has anyone experienced a runtz voltage resistor that self-destructed?
Yes, I had it correctly hooked up and properly grounded. But, I still didn't have a functioning gas gauge. frown I had a new sending unit also and it was properly grounded. No matter, the gauge still read empty. :mad:
Today, the cab filled with smoke on me. eek I shut 'er down in a hurry and disconnected the battery. After the smoke cleared, I found that the Runtz had gone up in smoke, melting its blue plastic cover. eek I sure hope this didn't ruin the gauge.
Has anyone else experienced this?
#87764 03/09/2004 4:29 AM
53,
I have used a Runtz for a couple years now and have never seen this happen. How long did your Runtz last before this happened?
Craig
#87765 03/09/2004 4:48 AM
It's been in the truck ('53 1/2 ton) about a month. No sign of smoke until today! :confused:
#87766 03/09/2004 3:34 PM
I would email Randy Rundle the Moderator. As he is the Inventor of the Runtz I believe there is a link to Fifth Ave in the link section.
Please let us know what happens.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#87767 03/09/2004 5:08 PM
I had one that fried, although not quite as bad as yours. I talked to Randy and he kindly replaced it. No charge. Your best bet is to give him a call. He can tell you if you may have had something wired up wrong to cause your problem.
Good Luck
George
#87768 03/09/2004 5:25 PM
I have also had problems with the runtz. My '49 doesn't like them. I have the power lead coming straight off of the battery & it is grounded correctly. I have replaced it a couple of times. It works for a while then just dies and bingo no gauge again. I just watch my odometer from fill up.
#87769 03/10/2004 2:47 AM
I have blown a couple of them over the years. Mine seem to have blown when I forgot to turn on my main battery cutoff switch before turning on my ignition switch. If I turn on the ignition switch then turn on the battery cutoff switch, I'll hear a pop then the gas gauge wont work. I cut open the blue insulation on the burned out ones to find that usually its one of the little brown capacitors or whatever they are, that actually crack apart.
#87770 03/11/2004 12:42 AM
Mine died this weekend. It was working intermittantly and would cut out after a few minutes of running. I have a brand new wiring harness and a new Delco alternator. I'm going to dissect it and analyze it to see what happened.
Paint & Body Shop moderator
