| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 12 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 12 | Does anyone besides Holley make a 4 bbl small enough (390cfm or so)for the 235? | | | | | Joined: Feb 2004 Posts: 29,785 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,785 | I believe Carter made a tiny 4-BBL for the dual 4BBL option for the 1956 Corvette 265 engine, but finding one that hasn't been worn out and rebuilt several times might be a real challenge. Jerry
| | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | These were model WCFB and were like but slightly smaller than the common WCFB used on the "power pack" 265 and 283. The carbs for the 2X4 corvette were stamped 15/16 on the bowl near the venturi and the common 4 barrel carb was stamped 1.This was seen looking down through the air inlet. The 2X4 carbs would be scarce and pricey when you find them---the power pac carb is a lot more common. 57 and later had a velocity valve in the secondaries that the 55-56 didn't.This would be desirable on a street engine to delay the secondarys opening at a too low RPM. No all mine have a good home and are not available. Just thinking the early Buick (straight eight), Olds and cadallic used the small carbs with a smaller flange but otherwise same carb until the big flange(mounting flange) came in in 55. Also Ford, Lincoln, Mercury had a small flange small carb until 57 but I didn't love those things with the float bowl up in the air cleaner---looked like a GM throttle body injector.
Bob Taylor
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
