9 members (cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
109
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87730 08/30/2003 4:57 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | This diagram was created by Chief; since the factory manual doesn't have a "full color" view. Chief, very fine work, sir  . I hope you don't mind me sharing it here. (It was on here before, folks; just a long time ago) AD wiring diagram (Thanks Chief)
*** GMC ***
#87731 08/30/2003 5:08 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That's all well and good but how do you wire the horn?
Very nice job Chief. Thanks, gmc248.
Tim | | |
#87732 08/30/2003 2:15 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I am assuming that this diagram is for peolpe who have converted to 12 volts since the bulbs shown are all 12V bulbs. Here's an origingal 6V factory wiring diagram if it's of any help to anyone: 1947-1954 GMC Wiring Diagram | | |
#87733 08/30/2003 5:59 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | OCK, your GMC wiring diagram is for positive ground system. Let's not confuse the Chevy guys........... BTW, what's wrong with 12 conversion? I know mine started a lot faster.........
*** GMC ***
#87734 08/31/2003 4:00 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | gmc248, That drawing is so purty that it should be framed and placed in NYC's art deco museum, called "wired".
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
