2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 24 New Guy | | New Guy Joined: Jul 2011 Posts: 24 | Been looking for a rebuildable 6v generator (1100028). Seems like every one I find is missing the id tag...Is there a way to id a 6v generator without the Delco tag on it?? (would the number be stamped anywhere else)
Any info appreciated Thanks, -Paul | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | I believe there's a measurable difference in the field coil resistance between 6 and 12 volt generators. I've got a couple of each stashed away, so as soon as I can dig 'em out I'll do some comparing. Most of the 12 volt generators have a stepped-down housing shape, and are longer than 6V units, also. I believe the 6V generators have big slots in the rear of the housing covered by a spring steel band, while the 12V units have a solid housing in the brush area. Jerry
