0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | Hi all, after i rebuilt my 235 engine 3100 miles ago i noticed it had a wobbly distributer. (1962 235) I took it out and clamped the shaft in a lathe to check the starightness and sure enough it was a little bit bent.(not majorly bent just very slightly) I strightened it out with my adjusting tool "hammer" so it was perfectly straight. If i recall correctly it was good for about 1 minute then it got the same wobble back in it when it runs.  Is this a common for 235's? is there a way to fix it? I noticed the shafts on these are not ver big diameter. I've been running it like that for 3100 miles and it is ok so far. Is it something i should lose sleep over? And no i do not want to but something newer in, thanks. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | PJ alot of the venders out there offer Distributors for sale. You should be able to find one for around $100.00 us.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Check out your local NAPA on that part. If your NAPA guy cant find the correct part # I can. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Last time I price a rebuild from my local parts store it was $35. Course, things are a lot cheaper here "south of the border". I would be careful and not drive it at high speeds until it's fixed. I was running a 478 GMC v6 with a worn out distributor. new one on order, so drive it the boss said. That afternoon at 65 mph with the governer engaged at 3250 rpm she misfired and I picked up a piece of the block about the size of my hand.
Fred 52 3600 69 C-10
