3 members (panic, 2-Ton, 1 invisible), 133 guests, and 3 robots.
Topics128,260
Posts1,058,343
Members48,485
#87659 04/04/2005 10:35 PM
just saw a replacement "bulb" for taillights, at local swap meet, that was a LED (light emitting diode?) neat idea: no heat, much bighter. anyone used these?
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#87660 04/04/2005 10:43 PM
Riding in the Passing Lane
I have a third brake light that uses LED. Works great. Your turn signal may not work right. The flasher depends on a specific curent draw to function properly. smile
1972 Chevy c10 Cheyenne Super
#87661 04/05/2005 12:32 AM
I notice that all the new busses and commercial trucks are using them. Must be specially designed circuits. You don't need a flasher, just a timing chip to make them light up.
"Happiness equals reality minus expectations" - Tom Magliozzi
#87662 04/05/2005 1:42 AM
Z
Z Offline
you can get a flasher that works with leds.
#87663 04/05/2005 4:17 AM
I've had a high fail rate with these bulbs, in 2 different cars. reason is they string the LEDs in series to get the 2.2volt required. This is why you see burnt sections on LED taillights every so often. When voltage is first applied, the full 14 volts hits the first LED for a microsecond, which kills it quickly. I'm making my own using a 680 ohm resistor for each high-brightness LED and mounting them in a drilled backing plate. Each LED-resistor section is then wired parallel to each other. No failures yet!
Best of luck!
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
