2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
I'm putting a 261 in my 50 Chevrolet . I purchased a 261 motor . It's complete except for the oil filter there's two passages on the left side of the block very small 1/4 I'm guessing . Where the steel lines would go for the oil filter . I purchased a remote oil filter kit that uses 1/2 pipe fittings . What should I do. I don't want to get crazy and bore out the block
Post the numbers on the side of the block so someone can id the year of your 261. I'm not sure, the early ones may have had the small oil lines, however the later engines had 1/2" oil lines. There is a dowel in the side of the block that needs to be pushed in to make the engine a full flow through the filter. If you look in the tech tips you will see a conversion process for full flow.
Tommy
59 apache 1/2t
261 short stepside
1954-1957 USA 261s had the small holes/lines for a by-pass oil filter.
You will need reducer fittings and a restrictor in the inflow line in your remote filter.
Jim Carter now lists a remote by-pass filter head for a spin-on filter. This set-up seems to have a by-pass restriction built in.
1958 261 should have the full flow filter with 1/2 lines. You either have an earlier 261 or a 235.
My engine casting numbers are 3733813
I believe it's not a full flow oiling system which is fine . It's just going to be a weekend driver . So I'm thinking about buying a beehive oil canister . Throw the spin on kit in garage for future use on something else
Any chance the block casting code is 3738813?
I Checked the numbers on the block 3733813 are my numbers it looks like the motor uses the bypass oil filter the 1/8 pipe threads are used on the ports for the filter . I could try to find a original bypass housing or beehive for what I'll be using this motor for will be just fine
