1 members (Hotrod Lincoln),
76
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | hey folks, need some help on my 52 pickup 3 speed transmission. the transmission is making a loud whinning noise while in high gear only. depress the clutch and coast and the whinning stops. my assumption is a bearing going out, if so, how do i find someone to repair and where do i find the parts. i also assume a complete rebuild on the transmission since it is out. also, any thoughts on ballfield cost. i am in nw ala. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Sounds more like the front pinion bearing in the rear end.
See the USA in your vintage Chevrolet! My Blog | | |
