8 members (Hotrod Lincoln, Gdads51, Bill Hanlon, JoeDude, frogfarmer, tclederman, gswbbc, dt235sd), 85 guests, and 2 robots.
Topics128,038
Posts1,055,536
Members48,425
#874559 08/13/2012 9:07 PM
I own a 49 1/2 ton with a vin number of
GBA6414.....When i went to the serch location, there is no GBA...Anyone got any ideas???
Thanks!!!
Billm
billm #874570 08/13/2012 9:25 PM
Looks like a stock Flint-mfd 49 "3100" 216 engine serial number
http://chevy.oldcarmanualproject.com/chevyresto/4952.htm
Which was commonly used as the VIN back in the day.
What is the serial of the engine in the truck now?
Professional Novice
Frank50 #874576 08/13/2012 9:34 PM
Thanks Frank: I know the engine is a 54. I do not have the number on the engine, it is at my house in Georgia and I am in florida. When i tried to get insurance on it, they told me this was not the correct vin #. Not sure how I am going to solve it.
Anyway, Thanks!!!!
Bill M
billm #874590 08/13/2012 9:57 PM
It's a common problem with old cars and trucks as many states used the engine number as the VIN well into the 50's, if not later. The 50 3/4-ton I bought in 99 from a MO guy had the original engine serial on the title but already had been swapped for a V8 when he bought it 12 years earlier. He had a good MO title, it just didn't match any number found on the truck. MO had a special form the seller could use to explain any discrepancies. With that I had no problem getting a KY title.
Try to explain that the number on the title is apparently the original engine number and that the engine has been replaced...
Good luck.
Professional Novice
Frank50 #874608 08/13/2012 11:09 PM
Had the same problem bringing my '54 from Washington State to Canada. Funny thing is neither the US Customs guys or the Canadian Customs guys cared that the numbers on the title didn't match anything on the truck.
It took me about a month and a half transfering ownership to me and registering it in Canada. Finally the DOT gave in and registered it in British Columbia under the VIN number on the door post.
Only after I did a lot of researching how Washington State registered vehicles back in the 50's.
