4 members (UtahYork, cmayna, Otto Skorzeny, Bucker), 111 guests, and 0 robots.
Topics128,162
Posts1,056,916
Members48,458
Yesterday, Wednesday I was going to take the Blue Bird (454-30) to have it weighed. Get the unladen weight.
Everything had been working well, I had finished the wiring and tire changes. Had all the techs and specs adjusted. Engine was purring, brakes would stop on a dime and give you change.
Went to California DMV and got a One Day Moving Permit (they are free). So I was legal.
Started the truck, did a safety check, tires, brakes, gas level, oil and temp. All was well, so off I started.
Backed out my driveway, got pointed in the right direction, got over to Billy Road which is the steepest hill in Paradise. Heading down the road, up a slight rise, a little dip, up the next rise, touched the brakes and felt truck slow, then approached the down slope of Billy Road. Down shifted from 5th to 4th and applied brakes...whoooa no brakes, pumped pedal and nothing...pumped some more, nothing, no response. Being in 4th gear helped keep speed down the light ahead was RED, cross traffic ahead major 4 lane road, "The Skyway" ten I remembered the Parking/Emergency Brake, painted Fire Engine Red. So I avoided any collisions.
Went back home and parked truck disillusioned with it. Later that day a I went out and laid under the truck to take a look at what might be the problem. Could not find any visual problem. So I checked the master cylinder, it was empty.
Where did all the fluid go...I refilled the master cylinder, pumped it down..added more, pumped it down, repeated this 2 more times. Then I went back under the truck still no visible fluid leaks. Then out of the corner of my eye there was a drip, right over the muffler on the frame.
The steel brake line from the brake light switch tee to the rear axle had split open down the seam.
That is the first time in over 50 years of being a grease monkey that I have had that happen. I have heard of it but never experienced it for myself.
Now I have....it was an exciting experience. One which I could do without again.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Bet that was waaaaaay up on the Pucker Scale!
I need to redo lines on my '59 Fargo...
Glad to hear you and the truck are safe!
GMC: Get More Cash...
1958 GMC
My Webshots photos
I've had holes from rust before, but never had a seam split open. At least it's a fairly easy fix and you got home safely again.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
$12.00 for new steel brake lines and $6.00 for brake fluid is a cheap fix compared to what it might have been.
That is for sure, You have it all done and back together now then?
Tad
