3 members (texas46, Otto Skorzeny, 55shaker), 178 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
i had windows installed in my 1955 1st. all is well but the inside driver side window channel ( in the door on the latch side) the shop made one up but it is still not right. i need to help it stay straight on the way up as i crank it up. any help finding one that works? thank you . Brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Is this the part that you need?
< CLICK > Door rear window channel
If so, reproductions are available. Here are two: American Classic Truck Parts item #DGC-51L "Rear window channel", and The Truck Shop item #51-05803 "Lower rear door edge glass guide."
I bought one for my '54 3100 from American Classic. Perfect fit. Make sure that you use the correct size screw through the door into the guide. I used one too large and broke off the speed-nut type thread but was able to rig it to work.
FYI - I bought window kit #51-05705 from The Truck Shop (upper felt, inner wipes, outer wipes, staples, door division bars) and was very pleased with the fit. I ordered the glass guide but it was out of stock, so I bought from Classic.
< CLICK > American Classic Truck Parts Search for "Door Glass Metal Channels" under "Window Rubber/Seals/Kits - General"
< CLICK > The Truck Shop Bottom row, center column.
- Lonnie
My '54 3104
thank you lonniec. i'm just waiting for "the truck shop" to open up in california to put the order in.
You probably need a shop manual or a truck assembly manual.
Assembly Manual
Shop Manual
~Jim
Moderated by  ndkid275, Phak1
