2 members (Peggy M, Gray_Ghost),
184
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | Hello, does anyone know of a acid metal cleaner that can be purchased at a hardware store that I can dip/soak old rusted car parts in that will clean them up good?
1946 Chevy Truck Export Blue with Black Trim
| | | | | Joined: Aug 2012 Posts: 46 New Guy | | New Guy Joined: Aug 2012 Posts: 46 | I've heard great things about evaporust. I've never used it but it's supposed to be very acidic and do exactly what you've described.
I use a small ultrasonic cleaner w/ various solutions. Eats the rust away and leaves parts looking brand new. Harbor Freight sells the model that I have for under $80. Depends on how large the parts that you have are but if they fit, it's a great way to do it. | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | I use a small ultrasonic cleaner w/ various solutions. Eats the rust away and leaves parts looking brand new. Harbor Freight sells the model that I have for under $80. Depends on how large the parts that you have are but if they fit, it's a great way to do it. what's the name of the ultrasonic cleaner you use?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the tech tip about electrolytic de-rusting, works great and very inexpensive Bill | | | | | Joined: Mar 2012 Posts: 102 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 102 | does anyone know the name of the acid they use to dip car parts in before they dip them in chrome?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Using strong acids can adversly effect the metal your trying to save unless your not in a hurry and if your not in a hurry reverse electrolysis is way less labor intensive and safer with no future concern about paint failure biting you in the... End.
| | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | I'm not sure of the pre-chrome acid, but for de-rusting of parts that are not subjected to much stress, I use vinegar. Cheap and safe, but it takes a few days for heavy rust. I've also used evapo-rust. It works great.
For parts that are subjected to a lot of stress (engine, driveline, steering, etc) acid should not be used. It can result in hydrogen embrittlement of the material and the part can fail under stress. Plating also can result in hydrogen embrittlement. For high stress parts platers should bake the part immediately after plating to drive the hydrogen out. (If I remember correctly, it's 400 degrees for several hours).
Evapo-rust is fairly neutral pH and is safe on your skin. It's my understanding that it doesn't produce hydrogen embrittlement.
Dave Evans 52_3100 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I doubt you'll find any hydrochloric, hydrofluoric, or sulfuric acid at a hardware store, especially in Cali ... the chrome process varies, but doesn't normally involve real de-rusting Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | FLAPS sell the 'hard' stuff... It's called "Battery Acid" and will eat your fingers off.
The hydrogen also reverses itself naturaly if you let it sit for several weeks.
| | | | | Joined: Aug 2012 Posts: 46 New Guy | | New Guy Joined: Aug 2012 Posts: 46 | I use a small ultrasonic cleaner w/ various solutions. Eats the rust away and leaves parts looking brand new. Harbor Freight sells the model that I have for under $80. Depends on how large the parts that you have are but if they fit, it's a great way to do it. what's the name of the ultrasonic cleaner you use? http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.htmlI'm still working on finding the best solutions. Purple Power absolutely kills any grease/dirt. Vinegar seems to do a pretty good job on rust. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | This thread got me wondering about road tars and undercoatings in fender wells and similar places. From my experience none of the strippers have removed any and neither did reverse electrolysis. I say that from experience, having tried both routes trying to get paint to stick inside my fenders, on the advice of the guy who manufactures the paint I use, I finally borrowed a 40# sand blaster and got the job done right. At least I haven't been able to blow the paint off with an air nozzle like I could before.
So while I have been resisting the whole 'Blasting' thing for years as a C.heap A.ss S.tovebolt O.wner I have finally been converted. (you still have to be careful about the media you use)
For small intricate parts I can see the usefulness of a liquid stripper, but I see them now more as 'specialty' tools when 'better' tools don't fit.
| | | | | Joined: Mar 2008 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 55 | I work at the local NAPA store and we just put out on display rust remover soak made by WD40. Not sure of all the details but it was a gallon jug. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The Evaporust is good for things like rusted carburetors where there are other metals involved. It does not affect the other metals or plastic. | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | you can build an ultrasonic cleaner with an old sander. look it up on youtube. Mine works great for the little parts. For the bigger stuff I use the electrolysis, and gives me time to do other stuff. As for the undercoating... I'm a fan of a 4.5" grinder with a aggressive wire brush. Then coat it with evapo. wash and repeat, then seal it.
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | |
