1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
I was told having the tank behind cab seat results in fuel vapor smell. Is this an issue due to a tank seal being bad or worth relocating the tank under the bed? If moving tank please recommend a supplier. Thanks.
the pro's and con's have been debated the how to' told and most any question answered in the Tech Files and Archives all easily accessed using the Search function.
Give me ambiguity
or give me something else
smell is a non-issue if the tank is sound and the connecting hoses at the filler are good - there isn't a specific supplier for underbed tanks, you'd need to figure out something that would fit from the wreckers or get some custom hot rod sort of item, folks use a wide range of things
