| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | I was told having the tank behind cab seat results in fuel vapor smell. Is this an issue due to a tank seal being bad or worth relocating the tank under the bed? If moving tank please recommend a supplier. Thanks. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | the pro's and con's have been debated the how to' told and most any question answered in the Tech Files and Archives all easily accessed using the Search function.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | smell is a non-issue if the tank is sound and the connecting hoses at the filler are good - there isn't a specific supplier for underbed tanks, you'd need to figure out something that would fit from the wreckers or get some custom hot rod sort of item, folks use a wide range of things
Bill | | |
