0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
I have a 49 truck that is still 6v with an original radio. I get alot of static with the engine running. Where do I need to place condensers? And what type do I need? Thank you, Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Here is one thread on radio noise suppression.
Jim Carter might have parts and Chevs of the 40s used to have all the parts, including the suppressor that went into the coil lead on the distributor cap and the odd little "springs" that went inside the front wheel bearing dust caps.
Here are installation instructions.
You should put a condenser on the ignition feed at the coil and also on the batt terminal on the regulator. I was able to find a value in one of the writeups and it turned out to be the same value as the one used in the distributor of a 50s Chevy six. I believe they are .5 MFd. I did this on my 51 1 Ton and it made a big difference. The noise problem is more noticeable when you have a weak station signal.
I think the static ground devices for the front bearings caps were relevant with the old style tires. I doubt they would have any effect with modern tires.
1951 1 Ton Completed
