| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 37 | How long should the standard distributor, points,rotor set up last between tune ups or is switching to an electronic ignition worth it? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | With points you need to clean and adjust them every 1000 miles or so. Cap and rotor last a long time.
If you put 1000 miles a year on, I'd say keep the points. If you put 1000 miles a month on, I'd go electronic. | | |
