| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I picked up a '53 cab to replace the one that was damaged when hit by a Semi last year. The Cab is now repaired and painted, ready for attachment to the frame.
I believe I've covered most of the bases, but want to ask what you would have done before the cab is actually bolted down.
Here's an example of what I've done:
Cleaned and painted the frame, cab/running board supports, and battery box.
Re-attach the brake/clutch support assembly.
Re-attach the parking brake guide (Jim Carter calls an "anti-rattler") and assembly.
Re-attach the master cylinder and brake lines.
What else can you all suggest?
Thanks.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check the manual ...click... Step 9 and 11 tells you the clearance you need, shim if necessary. This helps with front end sheet metal alignment, body gaps. Side note. With the cab off you can stamp or etch your vin number on frame where only you know and hidden by cab. Just I case some wise guy get a crazy idea. Did you bleed our brakes and check for leaks? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Paint the bottom of the cab with a product like POR-15,I do it but use Cassis Saver to my cabs before remounting them that way I don't have to worry that the floor will get rusty again.
Pete | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Thanks, Gus and Pete.
I have done both- checked out the manual and treated the bottom of the cab with KBS.
I transferred the ID with the VIN from the '51 cab and attached it to the '53 cab.
I'm still playing with the braking system.
I just wanted to be sure I wasn't missing something relatively obvious.
Thanks again. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Changing your vin over on cabs can be a red flag, especially if at some point it gets inspected and the inspector knows what to look for. Be very careful when doing things like this. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How would an inspector know the difference between a 1951 cab and a 1953 cab (just the cab, not any other parts)?
Dave,
Will you be using a combination of other parts, or mostly 1951 parts? Which frame will you be using? What engine will you be using.
Good luck with your vehicle's resurrection.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Isn't it more likely the inspector will be examining the rivets on the inspection plate if he/she is doubtful about something? or maybe the condition under the plate?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you think the inspector knows which years used the "rivets" and which years used hexagonal-head clutch-head screws?
"Yes ma'am, I installed my ID plate after I painted the cab."
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's most likely Dave has the vehicle already registered, and the paper work related to the wreck, and the receipt for purchase of a replacement cab, which of course needs to be carrying the proper number plate for the registration ..... what can be doubtful?
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | my 50 uses philips head screws on the door post plate.
I almost had a bad day at the DMV over that. had to explain thats how it came from the factory.
the inspector had no idea, finally had to talk to an older supervisor
My earlier suggestion to transfer the vin number to the frame was for personal purposes, not DMV or inspection. as our AD truck have no frame stampping. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Isn't it more likely the inspector will be examining the rivets on the inspection plate if he/she is doubtful about something? or maybe the condition under the plate? Exactly. They get suspicious if it looks to be tampered with at all, such as being screwed on, etc. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | They were screwed on in some years. So, it looks like you cannot win, even if it is unmolested?
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | What else can you all suggest? Beer. In Alberta anyone with a journeyman mechanic ticket can sign off on a vehicle inspection and I can say for certain that some will simply walk around a vehicle and sign without touching it. The inspection is only required to obtain insurance and there is NO inspection done by any level of government so it's easy enough to find somebody who sees things your way if the price is right.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What else can you all suggest? Beer. In Alberta anyone with a journeyman mechanic ticket can sign off on a vehicle inspection and I can say for certain that some will simply walk around a vehicle and sign without touching it. The inspection is only required to obtain insurance and there is NO inspection done by any level of government so it's easy enough to find somebody who sees things your way if the price is right. Not if the vehicle has been wrote off and is being inspected for return to the road, or is coming from another province (or for old vehicles, isn't in the system). This is a completely different inspection and the inspectors are heavily regulated and need to keep records of EVERYTHING. For a regular insurance inspection they aren't regulated and anyone can do one, but for the inspections that apply to the majority of antique and custom vehicles in this province, you can't get away with a whole lot. The RCMP and DOT can inspect your vehicle and pull it off the road if they feel it's been tampered with. | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | I'm working on that right now. I need to apply for a "builder title" because it was VINed off of the engine... that has been long replaced.
So I need to have a rolling chassis with steering and some form of a cab. but not ready for the road. They inspect it to make sure that there are no numbers on it.
Next I need to have it bonded at x2 of the apprised value of it in the none running condition. This give it a taxable value to get the builder title.
That stays in place during the build process for however long that takes.
Once it is roadworthy, it goes back in for another inspection along with the "builder title" and is inspected for safety requirements. If it passes, then the DOT physically attaches a NEW VIN to it. At that point I take that paperwork back to the DMV and file for a change from builder to actual title.
You may go talk to them and see if there is a way to apply for a new VIN to replace the screw on tag....?
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | |
