4 members (Fannin, 2-Ton, Phak1, TUTS 59), 170 guests, and 3 robots.
Topics128,084
Posts1,056,085
Members48,434
Junior Member
Junior Member
yes I am new on the forum and want to talk about
our trucks and your truck.I have a question about
my 1963 chevy truck what is the top speed you think for a 2wd 2brl 283v8 not sure what it should do it is all stock 3speed I cant get it over 65 can anyone tell me about it thanks.
for a 1/2T . . . . mmmm maybe ok - 3/4T would prolly be fine - depends on the rear end ratio it has - get it runnin good, check the ratio, try agin w/ a buddy to pace ya at an agreed speed, or clock it over "flying miles" - the speedo might be off
She should be able to run 90. I'd start by checking the basic tune-up items. Points, plugs, timing, fuel filter. If those are okay it's time for a compression check to look for worn rings or leaky valves.
Fred
52 3600
69 C-10
If the truck has plenty of power, I would lean toward the speedo being off. It could have had the tranny or rear end changed.
BTW,,,, How good are your brakes eek grin
Eh, I think if he were going 90 he would know it?
54 3100 with 235
62 flatbed dump C60 with 261
Junior Member
Junior Member
hey guys,ya got your reply on the motor speed of the truck I hope some of the advice you gave will help thanks for helping.
