| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 7 New Guy | | New Guy Joined: May 2010 Posts: 7 | hello everyone I'm looking at buying a 1 ton but would like to know if these trucks are wider then the 1/2 tons any knowledge would be greatly appreciated thanks | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With a pickup bed an AD 1 ton is the same width as the baby trucks. Same cab, fenders, bed width, and rear fenders. I suppose the hub caps could stick out some but if any more it's not much.
Grigg | | | | | Joined: Mar 2012 Posts: 5 New Guy | | New Guy Joined: Mar 2012 Posts: 5 | Grigg, how bout some new pics of your newst project 1tonnner | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2010 Posts: 7 New Guy | | New Guy Joined: May 2010 Posts: 7 | Grigg thanks do you know about 1 1/2 ton or bigger trucks are they wider? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Not really, the 1.5 ton 137" wheel base uses nearly the same frame as the 1 ton. Although the 1.5 and 2 tons have "bigger" fenders they're not but a few inches wider than the small trucks. | | |
