4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
#871854 08/03/2012 1:42 PM
On a '37, 216 cid engine,is the oil filler/breather pipe a pressure fit to the block or is it fastened in some way other than the brace below the filler? Any advice on how to remove it?
CAB
It is a press fit. Sometimes they are hard to remove without damaging them. A block of wood and a hammer under where the down pipe comes out the main tube, tapping up, is sometimes needed.
My Blog
Yep. Press fit. I sprayed mine with a bit of PB, let it soak and then with a bar wrapped in a rag and inserted between the main canister and vent pipe, worked it back and forth until it loosened.
CAB
