2 members (dt235sd, Nhluvstruck), 149 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#871575 08/02/2012 4:02 PM
Well I think I lucked out..I had a very good trans guy check 36 tranny for Burb..and said seals & parts are hard to find..hated to take it aprt..so he checked it inside. It shifted very well, and what look like real good oil in it...He steamed it and I added 80 /90oil.to keep the rust away. How long should I keep that oil in there?. it'll be a while til we finish the entire engine...Thanks...Bruce
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
1 Offline
We have a restored '38 Canopy Express and I think the transmissions may be close to the same. I think you probably still have a 206 and mine is a 216. But to answer your question, let it soak until you are satisfied those seals have swelled up enough to do the job of holding the usual transmission fluid and will not run past the seals. For any more I'd try either Larrowe and Sons in Big Sandy, OR or the Filling Station in Lebanon, OR. Both have some good knowledge about this vintage of Chevrolet's.
Normbc9
