2 members (Peggy M, Gdads51),
106
Mod | | | Forums66 Topics128,169 Posts1,057,043 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | hey guys, I'm trying to locate some rear axle/full float hub seals. The only place I'm seeing them is chevsofthe40's. lists the same seal for 3/4 and 1 ton. Is this correct? do the 3/4 tons have the same rear end?
1953 1 ton panel
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If I'm not mistaken, 14 bolt rearends use the same seal. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Available at NAPA NAPA seal I just installed these on my '56 1 ton.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Man, I just ordered them online for a 3/4 ton, hopefully they are right. I do have to go by Napa today to order up the rear brake shoes though.
1953 1 ton panel
| | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Same seal 3/4 & 1-ton from 1947 through 1959 (and quite a few more according to NAPA)
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Looking in the Timken catalog, they list seal# 2081 from 46-72 and 73-present 14 bolts. | | |
