| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 7 New Guy | | New Guy Joined: Jul 2012 Posts: 7 | '58 Apache 6-cylinder- where does the clutch return spring attach (both ends)? did these trucks have Borg-Warner overdrives available as optional equipment? thanks....
'58 Apache LWB, 96,000 mile unrestored original; '31 Ford Coupe, 22,000 mile unrestored original; '31 Ford SW Town Sedan.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's a small eye on the clutch arm the spring hooks in, the front end originally attached to a tab off an oil pan bolt, but the tabs are usually long gone, so you'll likely need to make one or hook it anywhere you can with a straightish pull .... yes the BW OD was available for all Task Force years
Bill | | |
