| | | Forums66 Topics128,181 Posts1,057,174 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87079 02/26/2002 7:06 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What's the difference between an alternator and generator? What do I have in my 55 2nd? Is there any benefit of one over the other?
Dennis -there is nothing stronger than the heart of a volunteer-
#87080 02/26/2002 7:46 PM | Joined: Dec 2000 Posts: 20 Member | | Member Joined: Dec 2000 Posts: 20 | The Gen will charge a flat dead batt, where an alt will not. The alt needs some juice to activate the charging system. I think this is correct, any one else have something to ad? :p
Philip Bland 1961 Chevy Apache C-10 Shortbed Stepside 235 ci 1964 Chevy C-10 Custom Shortbed Fleetside 350ci Bedford,Ky
#87081 02/26/2002 9:05 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | If your 55 2nd is original , it has a generator..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#87082 02/26/2002 9:17 PM | Joined: Dec 2001 Posts: 146 Member | | Member Joined: Dec 2001 Posts: 146 | Philip,
You are correct, You can for example push a car downhill with a dead battery on, get in gear and it will start when the engine start spinning a little bit high. But let's take a deeper look. The generator has magnets inside and it is able to generate electric current fron a zero input, to make it simple. Also note that it does produce straight current. That is, the energy output is adequated to be delivered to the battery and to all the accesories in the vehicle. Note that it is a very good way to produce energy. Even some welding machines uses this devices as current generators to make welding possible. The alternator is a li'l different. At first it has no magnets, so it must be excited to start generating some current. If they are not excited, You can spin then as fast as You want, they will produce nothing! This needed excitation is put into the rotor, which transfer or induces electricity in the outer windings. The only hassle is that it output is alternate current, just like the one we can find in the plug at the wall. So it needs to be rectified in a diode bridge, an arrangment that converts the alternate current into straight current, just what a car needs. Nowadays almost all alternators are self regulated, in a way that they work as a stand alone item. Very reliable and very confortable to be installed in an older vehicle. Not to mention that they are smaller, easier to fit and much lighter than a generator.
Alexandre Garcia
#87083 02/26/2002 10:32 PM | Joined: Dec 2001 Posts: 92 Member | | Member Joined: Dec 2001 Posts: 92 | Works for me too!! I need alittle excitation to the rotor every once in awhile to spark my magnuts too!!! Hehehehehe Very good explanation of the principle in all kidding aside. But I do think it will be over Proffit's head the Calif.with the smog and all!!
Live every day to the fullest for tommorrow never comes!!!
#87084 02/27/2002 7:58 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks to all. I believe mine (on the 55 2nd) is original and now I know what a generator is. And if I get any money I will know which wire harness kit to buy.
