2 members (WICruiser, TexasA&M48Truck), 146 guests, and 3 robots.
Topics128,081
Posts1,055,959
Members48,430
#87038 05/07/2002 7:49 PM
I rewired my 53 chevy pickup and the horn wire is hot.I disconnected the horn button and it is still hot.The truck has been converted to 12 volts.I can not figure why it is hot. Everything else is working fine. Please advise, Thanks.
#87039 05/07/2002 9:59 PM
Are you still using a horn relay or did you do away with it? I rewired my '49 and converted to 12v. Ran a hot from the ignition switch accessory terminal to the + on two new 12v horns by the radiator. Then from the - on the horns back to the wire coming up the steering column. Press on the horn button and blasto! wink
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#87040 05/08/2002 2:50 AM
There was an old relay burned up and I thru it out. However, the new wire harness has a orange + and black - going to horn. The horn I have has one terminal + and the - is the stud bolted to bracket which is negative ground. I guess I'll give it a try. I'll let you know. Thanks!
#87041 05/10/2002 3:05 AM
It worked. Hooked (+) wire to horn. Insulated the mounting stud with a gromet and connected the (-)horn button to the insulated stud and mounted to bracket.Thanks again!!!!!!!!!
#87042 05/10/2002 11:11 PM
Hey Beep Beep!! Glad it worked for you.
