6 members (FishinToms53, UtahYork, Toadwart, Southerntruck, homer52, 1 invisible), 63 guests, and 2 robots.
Topics128,087
Posts1,055,999
Members48,430
#869980 07/27/2012 9:07 PM
Have a 56 235 with a 848 head that will not separate for the block... Looks like the head gasket is made of copper... Have all the bolts loose... Have left it hanging from my engine puller thinking that the block weight would pull it away... Tried hitting it with a wood block and sledge hammer... No signs of it wanting to separate...
Any ideas to get it off ?
Thanks in advance..
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
There's gotta be a bolt you've missed somewhere. Check it out thoroughly and I'm pretty sure there will be one more bolt sitting there grinning back at you!
After all bolts are out, air pressure? Just a thought.
I used to loosen stuck heads on Flathead Ford V-8's by backing the head bolts up about 2 turns, and starting the engine. Goose the throttle a couple of times, and the head was easy to remove after that!
big_eek
How many head bolts do you have sitting on the bench?
1951 1 Ton Completed
If all the head bolts are out ,check again,one thing you can do is take a putty knife,thin blade, and tap it in between the head and the block in one of the corners.That should break the head loose.
Pete
Hahaha, I've done the same thing as Jerry, but on Model T's!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
It broke free finally... Now to see if the I can get the pistons to move... Need to suck out some residual grit later on and see if it will turn over... Then we will see how the cylinder walls look...
Thanks again for the help...
Pour a couple of ounces of Kroil or some other penetrating oil on top of the pistons and let it sit for a week or so before trying to move the crankshaft. I've heard a mixture of acetone and ATF works well, but I've never tried it. Kroil is made right up the road in Nashville, and I've usually got a gallon can of it sitting around the shop.
I had put ATF/Acetone and Marvel Mystery Oil in it a few weeks ago but when the head came off the cylinders looked fairly dry for as much liquid was poured in to them... I put the plugs in the head after... More Marvel Mystery Oil in it now... Would consider using Kroil but seems it not carried out here Jerry...
The oil pump works great.. Did the screwdriver bit on the end of the drill and turned it until oil was coming out of the lifters... Hope the pump sent some oil to the bearings...
Found out the pistons are.040 and looks like not too many miles on it... It is a 56 truck engine with hydraulic lifters and had a 4 speed transmission behind it...
Off to the next phase, wait for the Marvel Mystery Oil to seep in...
You may want to look at the lifters again. A 56 truck engine should not be drilled to supply oil needed for hydraulic lifters.
My Blog
Kroil can be ordered directly from the manufacturer.
www.kanolabs.com
One of their biggest customers is the US government, so they don't do a lot of retail sales. They sort of stick to the industrial and government market. Kroil was in the supply system of every USAF base where I served, worldwide.
Dave, they look like hydraulic lifters but I could be wrong...
What is the engine ID (serial number)?
Tim
3837004 Block
03II870T56Z Pad #
T56Z
T = Tonawanda, NY engine plant
56 = 1956
Z = standard car engine, standard, manual transmission
All 1956 car engines supposedly came with hydraulic lifters.
They sure look like hydraulic lifters!
My Blog
