2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#870144 07/28/2012 3:34 PM
Hi yall! I was wondering on a 1963 longbed, how far the frame extends behind the cab? I would also like to know how far from the front of the bed the center of the wheel is? Thanks! I am getting ready to bob my c60 down to a regular truck length.
hardy541 #870200 07/28/2012 7:52 PM
well the w/base for an 8' bed is 127". the w/base for a 9' bed is 133". 127 is 3/4t and 133 is 1t
ron
padresag #870372 07/29/2012 2:47 PM
Back of cab, to end for rear frame rails on a long wheel base (127") truck, is approximately 95.5", but I measured several and it will vary +/- 1", depending on the mounting location of the cab. You may have to get a bit more scientific, with your measurements, whereas, bobbing a frame of a longer wheel base frame, rear of the rear wheels, will not render the same frame configuration as a factory long bed frame.
May I suggest putting the long wheel base bed on the frame, situated over the rear wheels, as you see fit, in order to determine the section to be removed from forward of the rear wheels and rear of the rear wheels.
