5 members (frogfarmer, Oldcaliforniakid, Woodcmiami, 1955 1 Series, Wally / Montana), 62 guests, and 2 robots.
Topics128,050
Posts1,055,671
#870181 07/28/2012 6:26 PM
I did a compression check on my chevy 235. I found that number 4 didn't have any compression. So I took the head off and found this-
[IMG]http://i24.photobucket.com/albums/c33/hotrodfink47/2012-07-26172006.jpg[/IMG]
My question is if this is caused by the rings not seating correctly? I took the piston out to get new rings but the Head of the piston says .06. I think this is pretty much maxing out the cylinder. I went by some auto parts stores and they don't carry any rings that size. Has anyone else had this problem?
Patrick's Antique Cars & Trucks sells rings up to .080 over
http://www.patricksantiquecars.com/chevy_parts.html
Have you checked with NAPA?
yeah they don't have anything either.
What year 235 do you have?
3B Offline
Hy berts53, I have never seen zero compression caused by rings, burned or stuck valves, but not rings, please check the head as well, hope that helps.
Its a 57-62 235.
X2. To have Zero compression you should be able to see past the rings into the oil pan! Roll the head over, fill the combustion chamber with a thin liquid and watch it run past a valve.
BC
1960 C60 pasture art
Wait for this to load.
Also, NAPA on-line says you have to call a local dealer and they will check availability at the factory. Their website can be difficult to navigate. Earlier today I found single-piston set of rings, but now I can only find full set of rings. Did you call a NAPA dealer?
This situation is a good reason to do a "cylinder leakdown check" before tearing the engine down. With the piston at top dead center with both valves closed and the crankshaft locked by either putting the transmission in gear and setting the brake or locking the flywheel with a set of vise grips, put air pressure into the cylinder through the spark plug hole. Repeat for all the cylinders. Listen for leakage at the carburetor (intake valve), the tailpipe (exhaust valve), or the oil filler cap (piston rings) Bubbles in the radiator indicate a cracked head or a blown head gasket.
Thanks for the help. I'm a newbie and all the help is greatly appreciated.
I had a cracked head. I had a crack coming from the intake to the exhaust valve on the number 4 cylinder.
