5 members (Napco Mark, Wheelie, baldeagle, RaNfLaS, Jeff Ogden), 69 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#87001 03/06/2005 9:38 PM
Junior Member
Junior Member
I have a question about the warning light system on a vehicle.
I have ask several people about this and still have no answer. I hope someone here can set us straight.
One of the first rules of electricity is (it follows the path of least resistance)
If this rule is right why does electricity run through the 15 OHM resistor when you have a charging system working properly but when voltage drops it travels through the light. Seems it should travel the same path both times.
Hope I am not being too ignorant.
Paul
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#87002 03/06/2005 11:23 PM
When the system is not charging there is 12V from the ignition to the light and it grounds on the other end, lighting the bulb. When the alternator is charging there is 12V coming from that direction also. With 12V on both sides and no ground the bulb can't light.
#87003 03/08/2005 7:16 PM
Junior Member
Junior Member
Thank You. Seems simple now.
Paul
like....the IRS
