4 members (Bill Hanlon, Wayne67vert, eclector, Otto Skorzeny), 92 guests, and 3 robots.
Topics128,034
Posts1,055,533
Members48,425
#869898 07/27/2012 4:14 PM
I have an all new fuel system from the tank to the carbs on my 55 pickup and it runs, but the fuel filter barely has any fuel in it. It is a clear filter right before the carbs. Can anyone tell me why it doesn't fill?
lifestoshort
Rick55 #869899 07/27/2012 4:21 PM
Not uncommon to have an air pocket in the filter, not going to hurt anything. If it wasn't clear you just wouldn't see it.
BC
1960 C60 pasture art
BC59 #869902 07/27/2012 4:24 PM
I also noticed that the fuel not coming in to the filter in regular spurts. Is this normal?
lifestoshort
Rick55 #869923 07/27/2012 6:16 PM
Yup, at least on my truck it is. Nothing.... spurt-spurt-spurt-spurt......nothing......repeat. Sometimes its is a constant-ish trickle.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #869951 07/27/2012 8:01 PM
fuel flow from the pump to the carb is controlled by the carb input needle/seat, if the carb bowl is "full", it's shut off and nothing is pumped, what you see in the filter is the fuel use, if it were a continuous stream you wouldn't be able to afford the gas wink
