4 members (baldeagle, Jon G, Oswald, 1 invisible), 57 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#869712 07/26/2012 7:08 PM
I thought maybe I would start a new topic as I can't find anything on it at all for us.
I was wondering what the width of the frame from outer rail to outer rail would be... especially in relation to the 1/2 ton.
So the next thought would be what the best type of suspension would be. The distance from the outer frame to the hub is the most important thing.
Obviously the options are
1980 truck suspension
Mustang II (really don't want to go this route)
S-10 based suspension...
It would be nice to not have to backspace the wheels to a ridiculous degree so that there is the biggest amount of wheel options...
So what you do you guys know on the subject?
ontheverge #869744 07/26/2012 9:54 PM
3B Offline
Hy ontheverge, could you tell us what year truck you're asking about?
3B #869769 07/26/2012 11:26 PM
A couple weeks ago I saw a '49 with a '79 front suspension grafted to it. I know there are plenty out there that say it can't be done, but it looked pretty good. The Olds 455 sitting between it's framerails looked nice too.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #869835 07/27/2012 8:52 AM
Also important is what you want to do with the truck?
One excellent option is the stock suspension, not independent but not a bad ride at all, and still a 1 ton truck.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #870479 07/29/2012 9:36 PM
Hey Grigg,
Yeah you and I actually talked together a while ago... unfortunately the stock suspension is not going to work for me... I want to drive it way to much including for work if I can... and a IFS is just going to suit me WAY better =)
Whitedog... was the 49 a 1-ton or a half ton? Just because I guess the 3800 frame is wider then the 3100's at the front suspension.... and a 79 grafted to a 1/2 ton from what I have heard already makes the track width wider....
And sorry!!!! I am asking about a 49 3800 =)
ontheverge #870649 07/30/2012 2:35 PM
It was actually a 3600 truck with a 70's 1/2 ton front clip. The rear of the frame had been shortened too, for a shortbed. I guess you can say it was a 49 3/4 ton turned 1/2 ton with a 70's front clip. (Boy, that's a mouthful.) I didn't climb underneath to see where it was spliced, but with the hood open , it was pretty clean.
"The Fake Truck"
Moderated by  Dusty53
