1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | I drive my 1949 Chevy Truck stock 216 alot on week ends and noticed it runs pretty hot, or I think it does. Usually according to the temp guage it stays just under the 180 mark most times all year long, but during this 90 to 100 degree temp it runs between 180 and 212 or so, is that normal for this truck? Thanks Sig | | | | | Joined: Sep 2008 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 105 | The 216 in my 51 runs around 190 all the time. Will creep up a bit if I'm in traffic but comes right down to around 185-190. What thermostat are you running? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | 212 might be a tad high, depending on how long it stayed..
my 235 never,never, run over 185 and this was hot Tx weather Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | My 216 NEVER runs over 180, even when I had to tow the bus (7ton) .
You know that 212 is boiling , don't you. So that is too high.
Maybe time for a flush of the system. Also antifreeze should be used year round , 30% for best protection , both from freezing (not happening where you are) and boiling (is happening!)
Regards | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, SiG, My 49 1/2 ton stock engine not rebuilt yet at about 130,000 miles has run at a steady 180 since 1974 when my dad got it to pick up fire wood and take garbage to the dump at the cottage in the Okanagan. It has done a total of 4, 300 mile trips since then up to the cottage and back to the lower mainland.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | What's the pressure rating on the radiator cap? That one should probably be running a 4 lb. or maybe as much as a 7 lb. cap. The boiling point of coolant rises 3 degrees F. for every pound of pressure, so you could get up to 233 before it boils with a 7# cap. It looks like you're getting into slightly dangerous territory when the temp gets over 200, assuming the gauge is accurate.
Infra-red thermometers are available from places like Harbor Freight or Northern Tool, and they can be used to check the accuracy of the gauge without removing the radiator cap and exposing yourself to a potentially painful boil-over. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Stock 216 1/2 ton truck engines came with 0 psi radiator caps and 150-160 degree thermostats.
Full-pressure standard 235 1/2 ton 1954 truck engines came with 4 psi radiator caps and 150-160 thermostats.
Even good engine rebuilders not always carefully cleaned out the rear-most end of the block. This is one significant contribution to a hot engine (that has a good radiator).
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | My timing was off when mine ran hot
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | I will add to my above post that my truck is running a 0 PSI rad cap, also that my dad put about 1500 miles per year on it from 74 till 05 when he gave it to me. I think that it has a 180 deg. thermostat in it, but I am not positive about that.
