| | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86861 03/22/2002 6:20 PM | Joined: Mar 2002 Posts: 18 Member | | Member Joined: Mar 2002 Posts: 18 | I haven't quite been able to figure this out. Did all six cylinder PU s have foot starter or were key switch starters available as an option after they were introduced on the V8s ? Were key switch starters only used on V8 automatics or standards also?
Life is to serious to be taken seriously
#86862 03/22/2002 10:33 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Chevrolet began using electric solenoid starters on all their straight-six trucks about 1960-61. My dad's '59 Apache had a 235, 3-on-the-tree and a foot mash starter. His '62 had the same setup, but with an electric starter. Don't know about the V8s, Id assume it was about the same time.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#86863 03/23/2002 1:10 AM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Ogre; My 49 GMC had an original foot pedal starter button on the floorboard. Engine was changed to a 12v 261 and the starter was changed to a pushbutton on the dash. Have a key ignition which I turn on and then push the starter button. Really neat as it brings back memories if a Triumph Spitfire that I had years ago. Kind of cool too, pushing the button instead of "turning the key"! | | |
#86864 03/23/2002 2:32 AM | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | As an aside, if you drop your truck with a foot starter off at a shop, be sure to tell them that the straight up key is "on." My glass shop fellow turned the key all the way to the right (keyless off position) and drained the battery trying to get it started. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#86865 03/24/2002 5:20 AM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | gotta differ with you guys. own a 51 coe ALL original. have 2 poition key switch with a push button starter. other trucks i've owned 58 apache--standard ign. sw 54 che 1/2---2 position ign. push button 51 2 ton 2 position sw.--push button 50 1 ton--floor start 51 1 ton --2 position sw.-- push button 55 1/2---standard ign. sw i never saw a floor start switch after 50. not saying there were'nt, but i was i started working in a gas station when i was 9 years old, and srarted doing mechanic work when i was 13, and changed alot of starters when these trucks were'nt old. i'm 50 now, and still messing with old stuff---now called antique.  | | |
#86866 03/24/2002 12:28 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | OGRE, My 53 GMC Hydramatic has a solenoid starter and a push button starter switch on the dash.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#86867 03/24/2002 1:05 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 6 cylinder Chevy conventional trucks with standard trannys had floor starters up through 1959 like Chiphead says.Some very expensive new high performance cars now feature a red button on the dash that is labeled "start".Will the mechanical floor starter make a return?Cool | | |
#86868 03/24/2002 11:43 PM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Koolkar, you really ever look in a car when you were in station? :p My 54 has foot pedal, My COE's have foot pedal, right in front of seat on Chevy's and my GMC's have push-button on dash's. GMC was "ahead" and had higher dollar options.  Chev used to 59, then went Modern with switch on dash with "start" position for their NEW design. Any Cab forward or cowl only trucks had push-button start on dash, even when others had the floor pedal. Delivery trucks and buses they were used for.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#86869 03/26/2002 3:11 PM | Joined: Mar 2002 Posts: 18 Member | | Member Joined: Mar 2002 Posts: 18 | Well now that we've got that straightened out !!!!!!!! :p
