2 members (ranchojuan, baldeagle), 42 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#868368 07/21/2012 6:39 PM
Does anyone know where I can get the speedo gear that goes on the output shaft of the three speed trans in my 59 GMC 1/2 ton. Rear axel is a 3.07. Cleaned lubed and checked everything else all OK but still doesn't work. Thanks
gmc59100 #868785 07/23/2012 11:01 AM
If it is an SM318 (which is the same as a Chevy) I have several drive and driven gears for them. Fred
rfs56trk #869947 07/27/2012 7:54 PM
Fred- thanks for the reply. It's the orginal three speed. 1959 GMC 100, 270 L6 I'm not sure how to determine which model it is. If you can help let me know. I need the gear that goes on the tailshaft that drives the speedo cable adapter. How much you asking for one of the gears if you think you might have the correct one. Thanks for your time. Dave Enders
gmc59100 #870325 07/29/2012 11:01 AM
Dave,
The SM318 has a 4 bolt side cover and is about 22" long measured from the bellhousing mount to the end of the tail shaft. There was also a Warner HD trans available which has a 9 bolt side cover. GMC also used a 3 speed that looks to be something similar to the trans used in a Buick or Pontiac. It's shorter than the Chevy trans but thats all I know about it. I'll donate the gear to the cause if it will fit what you have. Give me a call 562-225-5869
Fred
