| | | Forums66 Topics128,046 Posts1,055,618 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86828 01/23/2005 2:44 PM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | A couple of weeks ago I talked about a current draw I was having. Was getting a small spark when connecting the positive battery terminal. Well, I pulled the fuses, one at a time, and the spark was still there. Next I disconnected the alternator and the spark was gone. So, is my alternator wired incorrectly or do I need that diode thingy, or both. Thanks, Don | | |
#86829 01/23/2005 7:09 PM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | If I had to take a guess it would be a bad diode leaking to ground. If you have a test meter you could tear down the alternator and test the diode trio and the other diodes to see which one is bad. I'm getting pretty good at testing them for my brothers and friends Do you have another alternator you can substitute to see if the draw goes away? Joe Garcia
Joe
#86830 01/23/2005 7:19 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Go back to what Eric Amlie wrote on your other thread. If the battery isn't going dead in the short term and it is charging the battery at around 14 volts, don't worry about it. You have checked the voltage with a volt meter? ? ? If there is no other drain as you checked, charging at 14 volts, but the battery goes dead in less than a week, then the alt is probably bad. It can have one of the rectifier diodes short and still charge. On one of the auto parts store testers, it will still show good, but you will still have a dead battery.
'67 GMC 3/4 292 4spd
#86831 01/23/2005 8:20 PM | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | The alternater will have a small draw on the battery. Around 7 volts is normal. If it is up to 12 volts, then theres a problem with it. If you have a volt meter, take the neg wire off the battery and hook the volt meter to the battry and the other to the cable. ( if the meter reads 0, switch leads) Make sure every thing is off or else you will get a false reading. | | |
