| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 | Requesting a picture of a rochester carb on a 235. Actually pix of any nice 235 setup would be appreciated.
Arkansas 1931 Chevrolet 4 door sedan ~ confederate 1934 Plymouth PE 2 door sedan 1936 Ford 1/2 ton fat fendered pickup 1946 3600 pickup 1950 3100 pickup 1930 Ford Roadster parts pile
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Anything particular that you are looking for? I assume that you want a stock one-carb setup. Here's the Rochester B on my '54 3100 235: > Driver's side 1> Driver's side 2> Passenger's side with choke and throttle cables> LinkageVac line from Inline Tube via Chev's of the 40s. I bent the fuel line from scratch to mate with my Durex fuel filter and with my fuel pump which has in and out ports at 20deg to the block. An Inline Tube fuel line from Chevs of the 40s with fit perfectly IF you don't have a fuel filter and IF the in/out ports on your fuel pump are parallel to the block. The line clips are from Ecklers. Other vendors sell them, too. Your Factory Assembly Manual will show where to bend the lines and attach the clips.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 | Those are nice pix and great looking engine bays. Thanks for taking the time to post those.
What plug wires are u guys running?
Thanks for posting. Dean ~ Arkansas
1938 Chevy 1/2 ton Pickup 1940 Chevy 3/4 KD Pickup 1946 Chevy 3/4 ton pickup 1940 Chevy 1/2 KC Pickup 1939 Chevy 1.5 Truck
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Dunno about plug wires. They were on the truck when I bought it. They are visually the same style as on original '54.
