9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible),
89
Mod | | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Ok my 454-30 rear suspension will be needing new rubber bushing for the torsion bars soon.
Anyone know where to get them replaced???
Do not know for sure who manufactured the suspension.
The axle is an Eaton TSDP 166000.
Was looking over or rather up at the rear suspension yesterday and realized that someday soon the torsion bars will need new rubber bushings on each end. 4 in total.
I have replaced bushings before for Hendricks suspensions. So I am familiar with the process. These seem to be much simpler.
Remove 4 bolts, drop torsion bars, replace bushing, replace and bolt up.
Where to find bushing is number one question.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Dec 2009 Posts: 52 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 52 | Perhaps someone with a master parts catalog can get you a part number that you can cross reference. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GMCPic, the o.e.m. p/n for the bushings is 2016704, hope that helps. | | | | | Joined: Dec 2009 Posts: 52 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 52 | GMCpic, keep us posted of your findings. I will need them for my 450 eventually. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 |
| | | | | Joined: Mar 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 60 | I looked at my 1953 450 and it doesn't have the torsion bars yours does. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | None of these trucks have "torsion bars" as they're usually defined, a spring that supports vehicle weight. What you're asking about is often called a "torque rod" and it helps locate the axle in the correct position, not carry weight.
Grigg | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I have several 450, 550 and a 600 series that use that torque rod. I doubt that anyone furnishes a bushing for it any more. Unless you untrack heavy loads, you really don't need torque rods anyway. If I ever get the urge to replace bushings, it will be to keep the torque rods from rattling around and I will jerry rig some kind of bushing just to fill up the space.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe (from what I've seen/remember) the GMC trucks with torque rods use a spring shackle at both ends of the springs. Those without the rods have the springs fixed front and shackles at the rear. Not sure it's wise to remove the rods without also removing a shackle if that's possible? If it is probably takes some shimming for pinion angle correction without the second shackle.
Grigg | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Mine has shackles at both ends of springs, using radius rods to maintain axle alignment.
As Grigg said torque rods
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I looked in a Batco catalog from about 40 years ago and there is no listing. Batco, which went broke in the 1990's was the best source for odd stuff. In my previous post, I didn't mean to remove them all together. But they really don't do a whole lot other than keep the axle in place which doesn't require much. Spring ride trailer suspensions still use a similar set up except for not having any shackles at all. I think GMC only used this setup a few years. I think that you will probably have will have to get the nearest thing you can find to fit. Fitment is not all that critical. I just don't take mine apart because if I do, I will have to find something to keep them from rattling around. And I would have a better chance in finding something to fit because I still have a lot of parts for trucks and trailers that I junked over 30 years ago. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | The other GMC 454-30 truck I just bought has a more standard type of rear leaf suspension.
For now, mine are in good shape, but someday they will need replacing.
From my experience, some where out there is something that will fit.
Or I will make them from scratch.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | On oldGMCtrucks.com there is an GMC ACR723, it has the same suspension as my truck.
| | | | | Joined: Dec 2009 Posts: 52 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 52 | GMCPic, did you have any luck finding a source for these bushings? | | |
