0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Requesting a picture of a rochester carb on a 235. Actually pix of any nice 235 setup would be appreciated.
Arkansas
1931 Chevrolet 4 door sedan ~ confederate
1934 Plymouth PE 2 door sedan
1936 Ford 1/2 ton fat fendered pickup
1946 3600 pickup
1950 3100 pickup
1930 Ford Roadster parts pile
Anything particular that you are looking for? I assume that you want a stock one-carb setup. Here's the Rochester B on my '54 3100 235:
> Driver's side 1
> Driver's side 2
> Passenger's side with choke and throttle cables
> Linkage
Vac line from Inline Tube via Chev's of the 40s. I bent the fuel line from scratch to mate with my Durex fuel filter and with my fuel pump which has in and out ports at 20deg to the block. An Inline Tube fuel line from Chevs of the 40s with fit perfectly IF you don't have a fuel filter and IF the in/out ports on your fuel pump are parallel to the block.
The line clips are from Ecklers. Other vendors sell them, too. Your Factory Assembly Manual will show where to bend the lines and attach the clips.
- Lonnie
My '54 3104
Those are nice pix and great looking engine bays. Thanks for taking the time to post those.
What plug wires are u guys running?
Thanks for posting.
Dean ~ Arkansas
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Dunno about plug wires. They were on the truck when I bought it. They are visually the same style as on original '54.
- Lonnie
My '54 3104
